First time post, I have scoured most of the site and tried anything related I could find.
1989 mj, 4.0, 4wd, automatic.
I got the rig recently as a project swap from a random car lot. They were able to get it to run momentarily using ether to show that the engine its self was in decent shape. 👌. Now that I have it home it will fire up perfectly fine, but then immediately shut its self off like the key was turned off.
Things I have done so far:
Replaced distributor cap and rotor.
Replaced all plugs and wires (verified gap on new plugs).
Replaced/repaired any vacuum hoses I could find.
Replaced crank position sensor.
Replaced fuel filter.
Verified power to the fuel pump.
Verified 40 psi in fuel rail.
Jumped the balast resistor.
I even tried starting it with the pump wired straight to power constant (via the relay and at the resistor out).
I am at a loss for what could be preventing it from staying running at this point. I can't seem to check any codes as the "maintenance" light does not illuminate (swapped in a known good bulb).
Any advice, or ideas would be greatly appreciated.
Thanks in advance!
