Captin840
Everything posted by Captin840
  1. The battery is about 5 months old, and yeah battery connections are good and tight.
  2. So I have a 1990 comanche 4.0l inline 6 renix. I have a snow blade attached, and has been attached (During the winter months) since 1998. Never had an issue with it until just recently, I know when you use something like that the the battery will be drained to an extent, but the other day while I was plowing I stop and then all of a sudden the truck died. Sounded like the battery was drained, checked it and it had 12.31v. Went to jump it with another truck and it wouldn't start until we moved the ground wire around and it fired up. Then when lifting the blade up it almost completely drains the battery and wants to die. When the truck is running the battery says it has 13.58v. So I'm confused, and my question is, is it a bad ground wire because I know there garbage on the renix style engines, is it the small alternator not having the power to keep it going? Please help, I live in eastern washington and it loves to snow over here.
  3. So I have a 1990 comanche 4.0l inline 6 renix. I have a snow blade attached, and has been attached (During the winter months) since 1998. Never had an issue with it until just recently, I know when you use something like that the the battery will be drained to an extent, but the other day while I was plowing I stop and then all of a sudden the truck died. Sounded like the battery was drained, checked it and it had 12.31v. Went to jump it with another truck and it wouldn't start until we moved the ground wire around and it fired up. Then when lifting the blade up it almost completely drains the battery and wants to die. When the truck is running the battery says it has 13.58v. So I'm confused, and my question is, is it a bad ground wire because I know there garbage on the renix style engines, is it the small alternator not having the power to keep it going? Please help, I live in eastern washington and it loves to snow over here.
