pookie
Everything posted by pookie
  1. I need help on how to remove the lower transmission line on the radiator on a 88 commanche with the 4.0 and were is the best place to buy a new radiator
  2. I'm sorry its the 4.0
  3. I've got oil leaking down and hitting the exhaust pipe in front of the transmission pan were the pipe makes the bend just below the oil pan drain plug.any opinions on were its coming from I thought maybe from the valve cover gasket or rear main seal.any suggestions Thanks.
  4. I have a bad knocking sound comeing from under my cab it only does it when its first started for the day and when i make a left turn.i think its the exhaust pipe were it runs above the crossmember,how can these be fixed or could it be something else wrong around the crossmember makeing it hit. THANKS
  5. I have a 88 comanche pioneer 4.0 liter.When i first start the truck the idle will speed up then goes back down to a real low idle and it keeps doing this over and over until i drive it to work a few miles then it seems to idle correctly.But it still seems to idle lower than normal.ANY suggestions on fixing the problem.THANKS
  6. Does anybody know if the wheels on a 2003 jeep wrangler X have the same bolt pattern has the comanche. 5x4.5
  7. I'm sorry i meant a receiver hitch thanks for the answers
  8. Does any body make a drop hitch for the mj
  9. Thanks eagle, I live in tennessee i don't think it matters down here. Does most jeep wheels have the correct backspace if there 15x7 wheels and what models come with the correct lug pattern its 5x4.5 right.
  10. I'm not set on getting 15x8 wheels 15x7s is fine with me.I am just trying to find out what would be the best setup with out rubbing to much and spending money on tires and wheels that don't fit the truck.I need new shocks anyway the ones on it now have seen there better day.THANKS for the replies.
  11. If i used 30x9.5 tires with 15x8 wheels would it rub anything and were is the best place to buy new shocks and what brand.
  12. I'm sorry its a 88 pioneer 4x4 so could i run 30x9.5 on 15x8 aftermarket wheels with out any rubbing issues and if i bought a 2 inch lift how many mods to you have to do to the front end. which brand to yall recommend for the lift. I'm new to jeeps i have always had older chevys any help would be appricated.
  13. Hi i just bought my first commanche and was wondering whats the biggest tire size i could run on a stock setup. I was thinking about buying 15x8 black steel wheels and what would be a good backspace. Thanks this is a great site.
