Justanoldmanche
Everything posted by Justanoldmanche
  1. 1990 Sportruck Red 2wd 4.0 5 speed ax15 short bed Smoker vent windows, three pane back window 44 rear (not sure if factory or not) Grey interior, bucket seats, floor shifter. Basic guages. From what I know, it has been in OH its entire life and resides in columbus OH currently. 108k on the odo. The only thing I can figure missing is the rear cab backing board, factory radio, and antenna. Restoring and adding what I can. Currently added turbine wheels, possible sports bar come Thanksgiving. Looking at doing a reproduced Lund Visor next year. (Front end was being repainted in picture)
  2. Update: Looks like I accidently kicked the fuse block or something but fuse was loose and partially broken. Thank you for the help
  3. I have not yet, will do once I find time to work on it again. I'll check on that when I work on it again.
  4. Ok, first post since getting my comanche. 1990 2wd 4.0 5 speed. The left side 'cluster' (parking break emissions check etc) were working fine as well as fuel. ( basic cluster with dummy oil etc) Noticed when I got home from driving at night that they were no longer working. I have checked fuses and seemed fine. Instrument ribbon on back look clean as well as connections. I was in the middle of testing fuel sending (unplugging, cross grounding etc) but got busy with dinner and kiddo. Turn signal, high beam, back lights all work. Door chime works (key in with door open)
