Damonk90
Everything posted by Damonk90
  1. Where does the ground, ground to is what I'm meaning. Going from the spade connector on the back to?? The only black negative wire I have is the I believe right rear neg
  2. Hey all, not sure if I can use this website this way to pick brains but!! I am restoring my 88 pioneer 4.0. Ran into a few bumps such as cleaning up all hacked up wiring. I have gotten the factory radio plug back into place but, where does the head unit ground connect to? Only black I have found is for I believe right rear speaker. Am I completely missing a wire? There is also the gray power antenna wire. Does that have to be plugged in as well? NEXT UP My interior lights. Have done cruisers ground for instrument panel etc. But can not for the life of me get the cab lights to work by the switch or door. Replaced bulbs and was not the issue. Any ideas, have a diagram, or a tip?? Thank you in advance!!! Long project ahead!
  3. For some reason when I go to add just 1 of the several I have it just loads and loads and loads. Don't know if it is me or the website.
  4. Vin: 1JTMP63P7JT256238 Y/m/m/t: 1988 jeep comanche pioneer short bed Motor/trans/transfer: 4.0 , aw4 4 speed, AMC 231 Build date: door stickers are non existent. Location: bartlesville oklahoma! NE OKLAHOMA Status: on the road driven a few days out of month to work. Middle of completely restoring Notes.: came with factory as I can tell. Fog lights. power/comfort trans. Colorado red with a tan interior. Bench with auto on the column 4x4 on the floor tilt steering rear defroster?? 2 door and 2 back speakers. Ac/ heat Owner: myself Damon Klahn
