Yep, DC power and return. Using the K-suspension bracket that mounts to the water bottle. Drill a couple of holes and relocate the coil away from the block. What was Chrysler thinking? Electonics+Heat=shorter life or failure. I can find the coil pigtail but was trying to avoid cutting off the OEM connector for splices and yes, there is not a lot of wire to work with.
