Lukas Eder
Everything posted by Lukas Eder
  1. I’ll try that thank you
  2. Well it turns over the engine isn’t seized. Do you mean like the rings are stuck causing it to not get compression?
  3. New fuel filter as well when she came to me the tank was nasty and fuel pump was not working so I put a new tank and fuel pump in. The injectors weren’t misting after I cleaned them so I went ahead and just replaced them. Do you know of another sensor that could cause it to run rough and not start back again?
  4. I put a crankshaft position sensor on her and still can’t get her to start. Based off what I was told I checked the time and it was good then replaced the crank sensor and still nothing
  5. Has good spark and fresh gas good fuel pressure in time. Just can’t figure it out and just had a newborn and started a new job with long hours so I don’t have time anymore to mess with her that’s why I’m looking for someone to get her running for me I also put a cps on it as well thinking that could be the issue. When it last ran it started running rough and when it was shut off it wouldn’t start back up.
  6. Has good spark and fresh gas good fuel pressure in time. Just can’t figure it out and just had a newborn and started a new job with long hours so I don’t have time anymore to mess with her that’s why I’m looking for someone to get her running for me
  7. Looking for someone in the southwest Oklahoma area to come out and get an 89 Jeep Comanche running that’s been sitting for about 10 year’s . Will pay cash and gas. If anyone would want to quote me I’d appreciate it 580-339-3656Lukas. TIA
  8. Looking for someone in the southwest Oklahoma area to come out and get an 89 Jeep Comanche running that’s been sitting for about 10 year’s . Will pay cash and gas. If anyone would want to quote me I’d appreciate it 580-339-3656 Lukas. TIA
  9. Truck was sitting in my parents yard for about 10 years. When it was parked a coolant hose busted and spewed and once it was shut off it wouldn’t start back up. I’ve checked compression, gas, ignition, timing and everything is running properly. I’m at a loss I can’t seem to figure out what’s wrong maybe a sensor? Any suggestions?
