I have a 86 2 5l with an ax5 transmission with the extrrnal slave. I dropped the tranny to replace clutch, rear main seal, and bearings. My question has to do with the clutch fork release. When i pulled it out it seems bent at a higher degree on the left side then on the right. See pictures. But it does not look like its a stress bend more like it was cast that way.
Ive tried researching the topic and finding pictures and or replacements. But with very few results. None of the pictures i found for refrence had a side profile.
Also with the research i found; if it is bent there are no replacements for the 86. My only choice would be to switch to a 94 and up xj housing and get one of the readilly available clutch forks!?
I'm hoping any of you may have any suggestions or info. Thanks
