Cagr87
Everything posted by Cagr87
Thanks M👍
thanks AGUILA. I know I have asked a lot about this issue but I am new to this many things I do not understand, thank you for your time. Another question I have is if the speedometer cable is the same from the xj 95 as my mj 87
you tell me that I can use the same CPS of the mj 87 in the ax5 of the xj 95 thanks friend for your answers .. another question for the speedometer is the same or I have to make adaptations. thanks
the xj is transmission ax5 4wd the mj 2wd is problem adapt CPS in the transmission of the xj
Mj transmission ax4 and xj transmission ax5
Mj manual and xj manual
Is compactible transmission from cherokee xj 1995 4 cyl with comanche 87 4 cyl
can i put a dakota 2.5 bell housing on the BA 10/5 transmission to install it on the mj 2.5
Ok thanks friend
excuse me, I'm confused ... what it tells me is that I can adapt the T Case ax5 or 4 to my 2.5 transmission?
the ax5 connects to the 2.5? if they made 4wd for 2.5 if it is possible to add one
they did not manufacture transmission with 4wd for mj 2.5 ??
Good evening I have a question, what transmission do I need to make 4wd my jeep comanche 87 2.5L ... I have an engine, transmission, 4wd, front differential, ecu of a mj 4.0 but I do not have the 4.0 harness ... or is it easier to put one 4wd transmission special for the 2.5 with the front differential of 4.0 what do I do?
but my jeep does not come A/C from the factory
Could someone tell me where this two-wire harness connects, one is black and the other blue with an orange line, the cables come out together with those of the ISC engine harness
then the hood of dakota 2.5 manual does not work for the transmission of 4.0 ba-10
then the hood of dakota 2.5 manual does not work for the transmission of 4.0 ba-10 ?
Ok thanks
It is a lot of trouble to install the transmission and 4.0 ??engine because I also have the engine
I have the ax5 transmission of engine 4.0 what is the problem?
hi guys i'm new to the forum my question is if i can retrofit a 5 speed manual 4wd transmission and front axle from a jeep comanche mj 1987 4.0 6 cyl online on my jeep comanche mj 1987 2.5 4 cyl line 4 speed manual transmission
