Overlandmark2020
Overlandmark2020's Achievements
  1. Thanks for that info. I just looked at MTS and they do have that part. Ive put a new engine and all new parts that go with it, tried to start it this morning and it would not start. I dropped the fuel tank and everyting in there was eaten up with rust. I ordered a new fuel tank and straps from Amazon but could not find the pump. You made a bad day a little better thanks again.
  2. Does anyone know of a replacement fuel pump I can install on this comanche. The only part I can find is for the pump itself and I need the the pump and the housing for it as mine is rusted beyond repair. I've checked on here for that info and it all seems to be dated around 2010. I was wondering if someone has come up with a fix that I could use thanks.
  3. Thanks for that information, that's what I needed to know.
  4. I am wanting to swap my basic gauge cluster that is in my 89 comanche. I have 2 gauge clusters that are out of 90 model cherokees with rpm,oil , temp etc. My comanchee is a 2.5 4 cylinder and the cherokee has a 4.0 inline 6. My question is, will the gauge cluster from the 6 cylinder cherokee swap in to my 4 cylinder Comanche without to much trouble?
  5. I am replacing all the lights on my 89 comanche and the front and side marker lights plus turn signals are not working. Does anyone know where I could start looking to cure this problem? I've already checked the fuses. Thanks
  6. I'm looking to find a build sheet for my 1989 comanche vin# 1J7FJ36E8KL402701, Thanks!
