Well guys i bought another comanche, since its getting cold and wet i thought it would be a great time to test out its capabilities and get myself into a little mud racing event. Well as it turns out the joints are about as good after that as mine are in the cold, so i have some things to replace. I managed to blow out both upper and lower ball joints on both sides and one of the front axle u-joints, plus three out of four tie rod ends and probably some other things that i havent discovered yet but let's start here.
I lucked out and had a full set of good tie rod ends laying around but I'm still hunting down some other stuff, I see lots of different ball joints and u-joints out there so i thought it would be good to ask the professionals. What do you guys like to run for these? I have a spare set of u-joints already but they are just the autozone standard and I'm looking for a little bit of an upgrade. Side question, are the joints for the driveshaft and front axle the same?
What else would you recommend changing while I'm there? Wheel bearings? Any misc seals or bits and pieces? Any advice would be appreciated. Thanks!
