RedMJ
Everything posted by RedMJ
  1. Please man can you I will appreciate it ! I also wanted to ask you of what year is your motor out of ?
  2. Is your Mj short bed or long bed??
  3. If i get the Dakota gas tank n pump will it work with my 1988 comanche plug or would I need to change it to a 1997 plug?
  4. I think my Comanche still has the old wiring with only 3 cables
  5. Out of what year did you do your swap?mine is a 1997 Jeep Cherokee from what I know the fuel regulator is in the fuel pump right?? 1996 and lower the regulator is next to the fuel rail ? I’m I right???
  6. Why do you say that? Maybe I can get the newer gas tank and hopefully change the sending units
  7. I’m checking my local pick your part I found a 1990 and a 1998 Dakota right now
  8. Yea the Mj gas tank has the pump on the side and the Xj pump is top of the tank and the sending units are different.What I want to know is if anyone has change the tank from the Mj in order to make Xj pump fit and work?
  9. Dzimm yes i do have a complete swap. The only issues I have right now is my fuel pump it runs and all but my fuel psi pressure is at 36-39 and i struggle to turn it on and it also lags when I give it gas. By any chance do you have pictures you can post
  10. What model did you get the fuel pump and tank out of ? Was it 1998 3.9 v6?u got pictures of how u did it
  11. Hey guys so I have a 1988 Jeep Comanche with a 2.5....so long story short I swap the motor to a 4.0 but Now I'm having issues with the fuel and pump. 1997 fuel pump doesn’t fit in my gas tank. Anyone please help thanks in advance
