Engine 4.0 Inline 6
Trans. AW4 Aisin Warner 4spd. Automatic
Trans. Case Command Trac NP231
Front axle Dana 30
Rear Axle Dana 35
Shortbed
Tampa, Fla. across the street from my residence.
Not running and has been parked for 10 years in a carport.
Estate sale from my neighbor who recently passed away.
Neighbor purchased it from original owner just over 10 years ago in Woodstock, GA then had it trailered to Tampa. Had a Skyjacker 2 inch lift installed, Mile Marker winch, aftermarket bumpers, and 31 inch XMT Buckshot tires. Remember he said the engine was running rough and had to constantly add Sta-Bil to every fill up to keep it running. So instead 0f fixing the problem, he parked it and got another vehicle.
Forward to 2019. Purchased vehicle from family estate. Engine turns over but does not fire. No fuel pressure to the engine. Purchased fuel filter and fuel pump hanger assembly. Dropped the tank. Gas smelled like varnish. Pulled the original fuel sender out and it looks as though it sat in salt water for many years. Good ole ethanol corrosion. The fuel in the tank had debris floating on the surface. I can only imagine the sediment on the bottom. I have to wait to purchase a new fuel tank till next payday. That is my present status,
