photoguy_43420
Everything posted by photoguy_43420
  1. That's a good idea. I will try that first
  2. That's what I was wondering if a weak paint thinner would be okay. Just didn't want to damage them.
  3. Trying to remove the paint from my fender flares. I just painted my 88. Someone painted over them some time ago. It's flaking off. Any product good for this? I'm trying to restore the truck.
  4. MJCARENA Thanks! The way I routed it was through the square slot on the column and then to the clip "holder" on the column. Is that correct?
  5. I put another one in. It looks the same except it was not fraying. It seems like the cable is to long. The only selection I can get is low 2 and then the needle finally moves to park. That's what confuses me. I don't see how you can adjust this. Has anyone have an extra laying around? Would like to see another one and measure it. Thanks, Guy
  6. Here is what it looks like. How do you adjust this?
  7. How do you adjust the cable? I have done this swap. All I have is the cable and clip. I can't figure out how to adjust it.
  8. It is a 88. I just don't see how you adjustment the cable. There doesn't seem like there is a place for adjustment. Just the cable and clip.
  9. Okay did the swap. What I'm having problems is with the shift indicator cable. It seems like it is to long. I have the clip on the notch on the steering column. I put it in low 1 then it moves just a little from park.It is the same cable as before. Any ideas?
