DREADEDMONKY
DREADEDMONKY's Achievements
  1. I should add, I don't know enough about the brake light circuit to see why a frayed wire in the column connector would cause an always on condition.
  2. fixed the tailight issue- the brake power circuit wire in the column connector had frayed. I repaired the connection to the pin, and my brake lights work as normal. I've yet to see why the turn signal indicators are lighting up with the headlights. Thanks for the direction Eagle- I'll check the parking light circuits. I should have mentioned the PO swapped a XJ cluster in, and has really effed some wires. I've found multiple junctions under the hood for the ground using wire nuts.. Going tomorrow to the parts store for some wires and shrink wrap. Hopefully my electrical manual arrives this week.
  3. Also noted my taillights are constantly on. The pink wire to the pedal switch arcs when connected with constant 12v.
  4. Thanks for the replies- sorry, work has me busy. It's the blue wire in the radio harness. On the diagrams it's labeled tail lamp and minuit has a diagram with it labeled as such in his write up. Turn Sig indicators only are on when the head lights are on.
  5. Hi all, I have a Renix 1987 4.0. PO did some wiring and messed a lot of things up. I've just about got the wiring harness for the radio done, but had a 2 part question. (Waiting on the electrical manual). Whenever i turn the headlights on, my turn signal indicators light up. Is this related to the cut blue tail lamp wire in the radio harness?
