William
Everything posted by William
  1. My comache was 2 wheel drive then did the 4x4 swop so the leaf springs are on top of the axle
  2. So can I use the xj 6.5 long arme lift on my 89 Comanche want to know before I buy the lift
  3. I'm useing moter transmission and transfer case out of a 93 xj
  4. How did you get the xj cross member bolt in to the mj bc the xj cross member is lil longer then the mj one
  5. Ok man thanks for all the info
  6. Ok bc I'm using everything out of a 96 moter then a ax15 transmission
  7. I'm going to use ether a 95 or a 96 and what all do I have to change
  8. No nothing has been changed in the comanche
  9. 4.0 hight out put and automatic transmission and 33s I was thinking a 96 xj for the swap
  10. Rock crawling wend Don and was seeing what xj I could use to do the swap
  11. Ok so I have a 89 Comanche and want to do a 4x4 swap need to know what doner jeep xj I could use to do the swap thas would be easiest way possible
