Comnche tj
Comnche tj's Achievements
  1. Thanks a lot for that tip ill check behind de fuse block , will let you know how it went thanks again
  2. Sorry for taking your time, thanks for answering , will not bother you again thank you
  3. Yes all fuses ok including trans, ddont know where else to check
  4. Yes all fuses ok including trans, ddont know where else to check
  5. I don't have voltage on the two pin connector to switch, and on the 4 wire connector coming from top of engine
  6. How is everybody, I'm having an issue with backup lights on my 1988 comanche 5speed, checked all fuses under dash ok, checked 4 wire connector under truck no voltage, any suggestions? Thanks
