MrBill61
Everything posted by MrBill61
  1. Yes ,Yes why you asking this .It's running.
  2. No I didn't think I had to
  3. They were the jeep dealer they only had 5 in stock brought 2 from them then went after market .Sir
  4. Update What I ended up doing was replace the starter switch check the check the whole wiring harness no cracks no shorts no bad wires nothing all good in Iron Horse replaced the crank position sensor for the second time and the third time finally the 4th one worked and now runs again
  5. Some people o this are very rude . You asking for help and then they you treat like this. You got very rude people on this site .Big Dan
  6. yes ran and in time was great then my son park that night before. had this for last 10 yrs went fire it few days later. It for start for few seconds shut off . Then try to restart would not start .Then time chain was change about 3yrs ago.this truck is only use ounce or twice a myth.Also the way I time it 3 yrs gotrunnig it ran for last 3yrs
  7. Far as the coil no power to it no power to the ignition module and no power to cps.It does crank over . I'll have to buy new switch
  8. I literally look to see where the was point at the rotor make sure the crank was on top dead center and make sure the distributor point was a little Vance that's how I check timing . Been working on cars since I was 7 years old and that's how my dad told me to put things in time so that's how I check the time 57 years old
  9. Yes it has a brand new fuel pump on it too
  10. Replace the crank sensor position replace the ignition module replace the coil pack replaced ECM.also time dead on. still no spark need help
