Flatbedmache
Everything posted by Flatbedmache
  1. Just wondering what people have done with the seat belt brackets that go under the floor pan. The bracket drops down a good half inch just passed the frame rail. I can’t remember what it was like before I took the floors out. Did you leave a gap or hammer and bend the floor or cut and weld the bracket. Thanks
  2. Been a while since I’ve realky progressed on the manche. Finally decided on what I’m doing though. The more I took it apart the less I wanted to put it back together the same way. So I bought a 97 xj and I’m doing the whole swap. Stripped the entire wiring harness dash steering firewall and everything else I could use. I’m living with boxes of Jeep parts in my living room haha. Back to the manche, I decided to add 2x6 braces in the middle of the rocker panels for support as I’m not putting the cover support over the frame rail and floor again. Floors are almost all cut and just have to get around to welding them in and then modifying the firewall slightly to get the 97 dash in. Maybe before it snows. Maybe. (Don’t laughs at the welding on the passenger side. Was my first time and wasn’t using gas
  3. First coat in por15 for the back frame rails
  4. Dropped the gas tank. Going to replace with a fuel cell mounted on the deck. Got all the loots rust and dirt off the frame rails and as much and debris from the inside as I could. Going to prep and paint the rear frame rails in por15 and finally be done looking at any rust.
  5. Por15’d the inside of the frame rails today. Hopefully getting the passenger side 2x6 rocker on tomorrow
  6. Started putting in the rockers today. Got the drivers mounted up. Need a few random things before we finish off and move to the passenger side.
  7. Got my new floor pans. Didn’t take a pic of the drivers side but it’s a 2 piece. Need to buy some 2x6 steel for the rockers and some sheet metal to fab up the cab corners and interior front rockers. Then more cutting out of all the bad stuff.
  8. Getting the upper unibody rail supports off is a big whore of a job
  9. I swapped seat brackets and took the motors off when I had them in my 2 door xj. Just need to mount the rails to the Mj brackets. Not too hard of a job. Wouldn’t be that hard to make them power but I don’t feel like doing that much wiring
  10. Picked up an 88 comanche after rolling my xj. So gutted it and now I’m starting the rebuild. Started pulling the carpets to see what kind of work I have in store and it wasn’t as bad as I expected but definitely have some work going to be swapping over the leathers from a wj that I had in my xj to get rid of the bench seat. Switching the rad to an open system. Putting in a dual diaphragm brake booster. Swapping an ax15 for the Peugeot crap. Putting on some long arms and redoing the wood in the back of the deck. The list is really too long and it never really finishes anyway.
