MOVERALL
Everything posted by MOVERALL
  1. ok sir thanks is there a decent way to test it or just replace it? thanks
  2. hello I have a 87 MJ with 2.5, I had it recently rebuilt and it ran ok. Now it won't start and I notice the fuel pump continues to run as if its priming. It will turn over and etc. Tried starting fluid and no luck. I check the wiring harness by the master cylinder and it looked bad so I cut it out and went straight with the wires, but still doing the same thing. I read it could be the ecu. I checked it (a renix ef 8953004763) and it looks fine and does not smelt burned up any ideas would be great. thanks for your time
