franken_rubi
Everything posted by franken_rubi
  1. I stand corrected, it did used to say pioneer.
  2. Thanks. Technically it's my wife's jeep and she hand picked that color. When trailering it to my new house, it definitely turned heads. Hopefully that's a good thing. Lol
  3. It's a column shift, as originally it came with the bench before I put in bucket XJ seats. I'd have to go back thru my pics from when I was stripping it down. Could have sworn it said sportruck, buy could be wrong.
  4. 1989 comanche pioneer I bought several years ago. 4.0/aw4/np231 d30/d35 c-clip l, about 226k original miles and used to have a ton of rust. Ongoing project that stalled when we were trying to move out of the townhouse. But now have my own 1200sq/ft shop and should be finishing it up next year. Will have a rebuilt drivetrain, d44 rear, 4.56 gears, 35s, and a bunch of custom work on the interior.
  5. Thanks. It's been a journey. Everything I've done to this is pretty much a first for me. Only 2 things I dread is the electrical gremlins caused by the previous owner and the engine lifter tap. While rebuilding the top half of a jeep motor is nothing new to me, I'd hate to have all this work done and have to replace the motor. lol.
  6. Hello all. Thought I would share the build progress I've been making on the Comanche I bought for my wife last year. I've mainly clipped together the posts from my local forum and posted it below. Will post more as the project progresses. Hopefully I'll have Project X prepped, painted, and ready for interior restomods by mid-Dec, and axle swaps followed by lift and 33s by summer 2018. ENJOY! So I've always been interested in Comanches but never thought about owning one until a couple of months ago. I was browsing around for a cheap jeep to fix up and use for a daily and stumbled across a comanche for sale instead somewhat locally. I know a thing or two about jeeps and figured a comanche was pretty much a jeep cherokee pickup version. So I went out and bought it that night not know any detailed issues or history of the truck, just what was posted online. My intention was to build/fix it on a low budget and make it reliable enough that my wife could drive it, and that we can also take a 300 mile road trip with no problem. The first challenges were to figure out why I lost 3-4 gear on the way home the night I bought it and second was why it was running way too rich, also not idling right. While I suspect that the trans filter might be clogged or a solenoid is sticking, I did buy spare parts to replace them when I drop the trans. Now with the engine idle/richness, after familiarizing myself with how a RENIX jeep works, I quickly found out that the vacuum port on the TB that's supposed to connect to the MAP sensor was plugged, and the line missing entirely. So the MAP sensor was not getting any reading and telling the ECU to dump as much fuel as possible. Went to NAPA and bought some vacuum lines and brass adapter plug to add back to the TB. So this will be a continuous thread with progress as I complete it. So far the plan is to get the drivetrain as reliable as possible and have the following things done to it. -Floor pans (done) -Dash Bezel (done) -Chrysler 8.25 (bought not installed yet) -Gauge cluster to replace idiot lights (done, but needs troubleshooting) -97+ front clip (done) -97+ doors (done, just needs wiring) -bucket seats (custom seat brackets being made) -Speakers (6.5" from old jeep) Still looking: -4.10 gearing for D30 and C8.25 -D30 1 piece passenger side shaft -D30 lunchbox locker -C8.25 lunchbox locker -single DIN head unit -subwoofer -amplifier -4.5" lift shocks -iron rock long arms -4.5" lift coil springs -1 ton steering kit -track bar -4.5" lift shocks for rear -LED lights -33" tires -oil pressure sending unit -coolant temp sensor So to start, here is the comanche the day after I bought it, pretty basic. Next I drove it to work and had a little fun on the forklift, wanted to see how much (or little) flex it had before I eventually lift it. Next I found a $20 dash bezel to install as the comanche was sold without one. The interior looked much better once this was installed. So after I replaced the TPS, IAC valve, and connected the map sensor, I next decided to start working on the rust. I bought a pair of floor pans off ebay (still haven't started that yet), but I was unable to find a long bed or bed panels for the comanche cheap. So I sourced some 16 gauge steel and began peeling off the layers upon layers of bondo and fiberglass to get to the cancer that will get cut out. So ya, there were layers and a lot of them. After figuring out that I'd be there all day with a flap disk trying to peel off a cake, I took a screw driver and started to take off chunks at a time. This eventually revealed the body rot this thing suffered and the attempt to address it at one point or another. At this point I realized that the stock fender flares will never work on this again and I'll be building some fender flares from DOM 1.5" tubing at some point in the future. Next I started to cut the affected area which revealed that at some point someone attempted to weld rust together with some pieces of metal as filler. All that crap had to come out. Now here was where I started to challenge myself with welding sheet metal that my welder was too powerful for. Started to burn through the edges but figured it out after a bit. Not my best work, but functional for now and will get touched up once I fab up some flares. Also did the cut and fold for now which again is temporary. Next was the passenger side, which wasn't too bad. After learning from my mistakes on the driver's side, the welds on the pass came out much better. So at this point I found myself a donor cherokee. Most of the body panels are dented, but can be fixed pretty easily. First thing I did was swap the wheels from rusted steelies to alloys. Then last weekend I started to get a bit more aggressive in the build. Started off my removing the entire front clip of the comanche and laying out what I needed from the donor car. Next I went to pick to following from the donor. -Front fenders -Front grill, lights, and harness -Driver and passenger front doors -Front seats I did forget the door strikers, seat belts, and center console. Hopefully I can grab them this weekend. As she sits today, waiting for some new doors and floor pans. So started to tear into the interior this Sunday and man was it bad. The pics should explain everything. lol. First got the bench seat out. Soaked it in PB blaster prior but the bolts still didn't budge. Tried some penetration spray from work and they came out with ease. Cut a section out of the driver's side floor to reveal not one, but 2 license plates "patching" the floor. Then basically ripped out the rest of the floor which also revealed the passenger side floor which was "patched" with vinyl tile, galvanized sheet metal, and expanding foam. Since my afternoon was short, I didn't address the floor rust issue this time. I did go ahead and stick in the seats from the donor car to realize that I will need to fab up seat brackets for them to work. Sitting the way they are rose the seats 4" which is too much for me. Stay tuned. Update 3/26 Saturday was perfect to resume work on the comanche. While causing myself some stress by trying to rush install the new gauge cluster, I broke the speedo clip, and also need to troubleshoot why the tach, and oil sending unit don't work (yes the correct one was ordered for the new gauge). Anyways, only had time to repair the rust on the driver side and still need to add seam sealer, then POR15 it, followed by line-X. First started off by taking out the PA floor plates that were screwed in. The reveled how bad the rust was underneath, and how badly injured I could have been if my leg fell through the floor. Next vacuumed up as much as I could. Then I started to take pliers and pull on as much as I could. Next, cutting the affected area. Followed by some test fitting and trimming of the new floor pan. Then welding it all in. NOTE: If you are welding inside of a vehicle or near fuel lines, make sure you take any precautions to not catch your vehicle on fire. Even though I had as much as a could shielded (in addition to a fire extinguisher by my side), I almost caught the entire interior on fire. Luckily the first method to put out the flames with my fire blanket worked. Final product before I add the seam sealer. I'm hoping next weekend I'll be able to finish the passenger side before swapping the doors and wiring them up next. Stay tuned! 4/20 Update Got around to replacing the floor on the passenger side and also begun fabbing seat brackets for the 2001 bucket seats I took from my parts cherokee. As you can see the passenger side is far worse than the driver side was. Luckily no fuel lines in the way this time. Mocked up a half-cut. Then tacked it in place. Then did the other half-cut. Such a relief to not be able to see the ground from inside the cab anymore. Added some seam sealer to clean things up. Then moved on to the seat. I cut off the front and rear brackets from the driver's side part of the bench and tried to tack them to the rail on the 01 seat. Unfortunately it's not wide enough, so I had to weld on an ear to extend far enough so there are 2 anchor points. The back part (don't have pictures yet) won't fit at all since the seat adjuster mechanism is square in the way. So this weekend (hopefully), I'll be fabbing new brackets out of 14g steel to get the back of the seat anchored in. Then reinforcing the front bracket ears for a permanent seat. Next I'll be stripping the floor and giving it a healthy coat of POR15, followed by some line-x. Stay tuned. Update 5/21/17 So I found some time this morning to swap out 1 of the doors with the upgraded ones I took from my parts cherokee. Installation was pretty good until I realized I forgot to get the striker plates. So the door is ratchet strapped for the time being until I pick up and install the new striker plates. Much more of a PITA to remove the door from the Comanche vs the Cherokee So long ugly burgundy, manual windows and locks, and split frame glass... Test fit the new doors before bolting it down. All bolted in and ready for it's striker plate, followed by custom wiring to get the power windows, locks, and mirrors to function. UPDATE 7/16 Yes it's been a while. Since it's the busiest time of year for my company, I've been unable to keep up with this build as quickly as I originally wanted. Anyway, finally got around to coating the entire cab floor with POR15. That stuff gets everywhere, but is super effective. The cab looks a hell of a lot better. After 3 coats of POR15, I got the interior panels back in. Still contemplating painting/staining them black. UPDATE 11/06 With my first child ready to be brought in the new world in about a month, it's been a little hectic trying to get anything done the Comanche. But rest assured that progress is still being made. Last week I was able to score a nice set of 90 XJ seat brackets on ebay and finally get the driver seat permanently installed before the rain we had this past weekend. Lovely new brackets. Bye Bye 2001 XJ rails Bye Bye 1990 XJ frame brackets Hello to a little customization! Seat finally home! This weekend's plan is to get the passenger seat permanently installed, and to finish up the wiring of the power windows/locks. Then get this thing prepped and ready for paint!
