sandfreestyle
    SO CAL
sandfreestyle's Achievements
  1. Deaver makes a lot of over the counter packs that range from Chevy to Ford to Toyota. Yes, they will make you a custom pack but so will just about every other spring company. They are the best around at what they do for sure. I know the H70 is 55" from eye to eye straight, and 62" eye to eye along the arch. That is pretty close to the MJ.
  2. Look into Deaver leaf springs. I think they make a 58" eye to eye that may work. Those are some really nice smooth riding springs.
  3. While looking into it way more deeply this afternoon, I discovered that the leaf kit with shackles would run about $1700. So forget that. I'd rather save $1200 and not gain 5 extra inches of wheel travel and not have to deal with the headache. I could build a nice 3 or 4 link with coilovers for that price.
  4. The goal of the truck is more Jeepspeed but still be able to be daily driver. I was thinking a 4 link but don't want to break the bank on coilovers and bypass shocks as well as not being able to use the truck for a few weeks till the fab work is done. It will be attached to a trust 9" with Detroit and disc brakes. The leafs will also go under the axle as to not lift the back so high. I'm not exactly sure of the specs of the leafs but can find out real easy. I was just curious if it has been done before or even possible.
  5. Is it possible to put a set of 64" or 62" leaf on an MJ with out major modification? Has anyone done this before?
