W1ngzThinBlueLine
Everything posted by W1ngzThinBlueLine
  1. Does anyone know how to disconnect the dash harness from the rear harness? The one by the emergency brake, that runs the drivers rocker panel.
  2. So I got a little frustrated, grabbed the sledge and lightly tapped the fuses into their slots. I now have headlights. No turn signals though. I checked the provided website, some good parts near me so thank you for that.
  3. Pretty terrible huh? I wanted to replace the entire harness and simplify it in the process, keeping only what was needed. Is there a way to get the lights working until then? It probably did spend time in the gulf, there's water within 10 minutes any direction. I haven't been able to locate a fuse box anywhere I've looked, any ideas on places? If I plan on, in the future, doing the 97+ swap am I able to use a newer harness? My biggest concern is cost, I am underfunded, under-skilled, and overburdened. Thank you for the feedback. I'll take a few full size photos of my $400 Comanche. I've done some work already as seen in the first picture. Unfortunately my experience is with AMC Hornets and I thought it would be about the same. Sent from my XT1585 using Tapatalk
  4. Most of the inside fuses had to be pressed firmly with the meter probe and even then went anywhere from 0-9 volts bouncing around. This was done with the key in the on position. The fuse box under the hood only had one showing no volts. That's the 7.5 amp fuse there.
  5. Phone is dead so waiting to take pictures. Is there anything that controls the brake lights, headlights, and the turn signals? Any sort of sensor or fuse? I can't make heads or tails of the wiring diagram I have in the FSM.
  6. I have cleaned the grounds and tried to follow wires, but don't even know where to begin and feel if I open the harness I'm going to be overwhelmed. It is 100% stock, other than being chopped up a little by the previous owner. I will take a picture in the daylight.
  7. Good afternoon, BLUF: Removed dash, tampered with PO's wiring, no headlights, turn signals, or brake lights. This is my first post, and I hate starting a forum by asking for help (VS an intro) HOWEVER I am trying to get my Comanche to have lights as nothing seems to be working. I purchased my Jeep about 3 weeks ago. It had headlights, turn signals, and brakes when I started. I pulled ALL INTERIOR other than the headliner from the Jeep. (Broke all passenger seat bolts smh) And began working on the rust in the floor and firewall. There was a clustermess of chopped/spliced/taped/random hot wires going nowhere that I attempted to trace and remove. SOME WIRES were twisted around fuses which may be my issue. THE fuseblock shows signs that the clutch had previously leaked on it and damaged it. I am joining the Army (25 year old volunteer law enforcement currently, have kids part time, but no other family) Anyway, my recruiter needed me to head to his office and with the Comanche being my only vehicle, I bolted in the driver seat, 4 bolts for dash, and plugged in the gauges. My headlights, tail lights, and turn signals are not working. It doesnt help that Photobucket doesn't allow third party posting anymore so the dash uninstall post on the Cherokee forum can't be followed. I currently have the dash back out, and am trying to follow the FSM to no avail. Thank you in advance.
