Gents, below are some questions about my diffs, tranfer case and transmission, just looking for some expert assistance here on ID, specs etc.
My MJ is an 86 XLS, V6 auto Selec-Trac
The transfer case has a New Process tag, and is stamped with the following-
Model: AM 228
Assy: 89530 03970
Serial No: 123 (Mounting screw) 86-1
Ratio: 261
Is this transfer case any good or just a boat anchor?
The front diff looks like a D30 (Similar to my 98 XJ), dosent have Vac disco set up, but does have rubber boots covering between the inner and outer axles?
The rear diff Is also similar shape to my 98 XJ, 10 bolt round lid so I'm guessin its a spring under D35, with the load sensing valve above?
Another Question is - Any idea what my Ratios may be if still stock?
Auto Transmission is 3spd?, and from below the pan looks rectangular (long sides front and back) with the left rear corner cut off.
Is there somewhere I can post pics here? Might make it easier for you clever doods to ID all this stuff.
Cheers
Michael
