Having a pretty frustrating time with the signal lights. I really could use some help.
It seemed like it should be an easy fix but, after about 15 hours of fighting with it I'm still no further ahead.
problem is: when the right turn signal is activated both right signals flash front and back as normal but, the left turn signal also flashes at the tail light. However, when the left turn signal is activated ONLY the left turn flashes front and back.
When the brake switch is activated while right turn is selected both left and right flashing lights at tail stop flashing and remain illuminated until pedal is released/ switch opened and the flashing on both right and left tail lights continues
Searching this site and many others i have found many helpful suggestions and i have already done the following:
changed the multi function switch in the steering column,
replaced all 4 2057 bulbs in tail light housing,
cleaned sockets to remove corrosion and cleaned corrosion from inside socket assemblies wit wire brush/brake clean to make sure there is no short between the metal contact plates.
removed entire rear lighting harness to inspect for chafing/damages and physically seperated all wires for testing.
removed after market trailer wiring harness
refreshed ground behind drivers tail light
checked all 2057 bulb bodies for continuity to refreshed ground
cleaned and inspected harness connector in cab at drivers side beside hood release
seperated fuse panel halves to inspect for obvious burned/ chafed wires/ bridged terminals
With the right turn selected, using a digital multimeter, i continue to find voltage cycling from 0v-12v-0v present in the grey/blk wire (left turn) in the forward most connector beside hood release lever - with it disconnected from the tail light harness. And also continuity between the grey/blk (left) and the brown wire (right) at this connector with it unattached from tail light harness. I take this to indicate that the fault lies upstream of this connection.
What am i missing here??
Where do i look next??
Any advice or info would be greatly appreciated!!
also: Any tips for reinstalling the two halves of the fuse panel at the firewall? it came apart so easily, why is it near to impossible to put it back together?
Thankyou,
Al
-1988 jeep comanche 4.0
