fixerupper88
Everything posted by fixerupper88
  1. Well guys turns out was in fact the TCU. I had been watching a few on Ebay while driving by shifting manually and I finally scooped one up for 80 bucks and it works perfect. thanks for all the help. Is there any way to fix up my old one be reprogramming or something or should I just chunk it out?
  2. I sure can. Holy crap that will come is handy. Thank you big time.
  3. I can believe it. I’m more of a part changer myself and I’ve done more electrical trouble shooting following his lead with this than I ever have before. guess ya gotta learn sometime.
  4. Yes I am getting it between those two. Correct me if I’m wrong but isn’t the D1 connection for all the transmission connectivity to the RBT?
  5. Now that you say that I did already try my buddy’s TCU and had the same result. Unless there was some kind of procedure needed other then just plugging it in. How do you check the harness? just find a diagram and check for continuity on each end?
  6. Noooooo! well I guess the search for a good working one begins
  7. Well it does shift while rolling when power is put to the solenoids
  8. OK then I already did this without knowing because I had to drive it for two days while just manually shifting it. first gear works fine then I can't really feel a shift to second but third gear works good and then I can shift it into OD and stay good until I have to slow down eventually and must start over to take off.
  9. Ok thanks, I’ll finish that test tomorrow. Just curious would the solenoids have anything to do with why I’m not able to communicate with the TCM through the diagnostic port?
  10. Well I do hear clicking when I jump both of those pins but how do I verify they are actually working? Have the vehicle running and try to make contact and see if it down shifts and begins to roll?
  11. How do I do that. just cut 2 wires and jump the ground to ground and go to each other solenoid with the positive? I just ohmed them and got 17 on S1, 14 on S2 and 20 on S3
  12. Yes I do have continuity between those two points and I am getting 12 volts all the way to the TCM. Also I can read all other system info from the ECU just no transmission
  13. I have replaced the TCM fuse even though the old one tested good. My mechanic said he was getting some power to the unit while in low gear but nothing when in Drive so he suggested replacing Trans position sensor. But no good. I can’t seem to find the FSM diagnostic you posted Eagle. But it does shift good when shifting manually.
  14. I have thrown in the towel on figuring out why the auto tranny on my 88 won’t shift. (The start of the Problem) on two separate occasions when I started the truck and put it into gear it hesitated before downshifting so that I can takeoff. On the third time it refused to shift at all and stayed in high gear as it is now. I own a red brick and after the third time I could no longer communicate with the TCM. Have changed trans range sensor and tried a buddy’s TCM but no improvement. Also have completed the connecter and ground refreshments as well as checked fuses. Is there any way this is a tranny solenoid issue? Any help is greatly appreciated
  15. Ok so come to find out, this bad boy had a new rebuilt motor from O’reilys installed 40k miles back and has the receipts for pretty much every part of the truck from front to back since then. Called a number I found on the paperwork and talked to the mechanic that did it (don’t know how that actually worked since paperwork was dated 2010) and he said the truck is solid as hell aside from the floorboards being rusted out from sitting in the grass for 2 years. So what was bought as a parts truck is starting to look like a second working Comanche
  16. So I went pick up the chief yesterday morning. $400 and she’s all mine. Would only need a new fuel line and brakes to get her running from what the guy was telling and I can see from a quick look over besides the rusted floor boards. I know tearing her apart would anger the MJ gods but it also didn’t come with a title so I’m a little limited with what I can do with it.
  17. The chief is the same wheel base but does indeed have a 5 speed manual in it. What would my options be at this point? is it even possible to convert to 4x4 while still keeping it an automatic?
  18. I currently own a 1988 pioneer with the 4.0 and auto tranny. I already lifted it 4.5" because I knew I would be wanting to convert. today I have found a 88 4x4 chief 4.0 for very cheap. should I have everything I need to make this happen with that truck if all the parts are in ok condition?
