moonshiner
Everything posted by moonshiner
  1. a friend of mine that has scouts and jeeps said it was probably a dana 44 , i looked and it appears to be a dana 35 , so its probably due for a upgrade .
  2. any easy way to lower gear ratio on a 2 wd ? on a mustang i just changed the ring and pinion gear , i think its a dana 44 , fairly popular rear end , i would like to get it down to about 4.11 to 4.88 , its got a highway gear thats way too high for my use .
  3. i just found the oxygen sensor plug the other day and plugged it back up , i cleaned the plug , it was pretty dirty it had been unplugged for a long time , i also did most of cruiser 54s tips, checked for vacuum leaks , i added ground cables , cleaned all the connectors with contact cleaned and used dielectric grease , its running better than it ever has , it will still ever once in a while act like it just shuts off or loses fire while climbing a hill ? i guess i will check the CPS , fuel filter and pump next .
  4. hello all , i have a 86 comanche with a 2.5 amc 4 banger , TBI and a 4 speed manual , it has a few issues , the worst one , is that most of the it runs fine , then it will start cutting out like the fire or fuel is being cut right off , and it will also take surging spells at times as well while driving , this is my wood truck and its been a darn good one for the past 4 years , this all started this spring , i have already attended to fuse block and wiring harness figuring that was the problem and it fixed a lot of it but it still has a rough idle and a surging problem at times . thanks keith
