Kmr320
Kmr320's Achievements
  1. So this thing has serious wire issues. Had to run a wire from the ignition to the pump. Got fuel. But not spark all the time. May have to trace some more wires.
  2. Yeah I tried that. When I get off work tomorrow I'll pull the pump and see if I can get it to run in a bucket. It's wierd, I have a 1984 D150 and it has the same type wiring issues. If it weren't for the fuel injection I would've already gutted the wiring on the Comanche.
  3. Thanks. I found a bad connection for the yellow wire on the key switch. I've got fire to the plugs now and 11.3v to the plug by the fuel tank. But I can't hear the pump and no fuel at the rail. So I guess I'll pull the pump next.
  4. Btw, anyone know wth that little box under the steering column is with the little gears in it? Looks like clock gears. Idk. Thanks to anyone who helps I appreciate it.
  5. Hi everyone new here but out of ideas. Ok so here's the deal. My 87 Comanche pioneer is a electrical nightmare. I've done the c101 cleaning. Relays new and clean. Fuse panel cleaned. Grounds every freakin where. Cleaned and added xtra. I've been having trouble with the fuel relay and I recleaned things yesterday and got everything going except the alternator isn't charging.which is also new. Soooo I decided to change the ignition switch now the dam thing won't start. It turns over and the fuel pump is running. Not sure about spark. Waiting on help. Anyone have ideas where to go from here. Oh. Btw. It's a 4.0 renix 4x4. I have worked on this thing way more than I've driven it and it's a sweet running little truck. When it runs. Deer season is coming up and I need her to pull my boat. Lol.
