Big Dangus
    Chesapeake, VA
  • Interests
    Jeep and Jeeps
Big Dangus's Achievements
  1. Thanks MJ Junkie this may be just what I need. Big Dangus
  2. Just got the ol' MJ running after a V8 swap and an install of a 8.5 inch lift. I also replaced the wire harness with a painless kit and am having issues with the head lights and instrument panel, any wire diagram or help would be greatly appreciated. 1986 MJ 4x4 BigDangus
  3. I do not want to reuse the 4 cylinders radiator but it needs at a minimum the straight's 6 size radiator, guess my main question was will the bracketry fit with out major fabrication? I got a lead from Novak conversions that on a electric fan and radiator setup just need it to fit.
  4. So here is situation, I have just removed the 4 cylinder from my 86 MJ and replaced it with a sbc V8. After a multitude of problems from the drive train, bell housings, the clutch and a lot more i have finally progressed to turning the engine. However I discovered that the stock radiator will not support the the engine driven fan due to a clearance issue. It seems that the 4 bangers radiator was smaller and placed 4 inches aft than what the in line 6 was, so what i would like to try is find a MJ/XJ with the straight 6 radiator mounting brackets and try to install. Am i wasting of my time or does any one have any suggestions?
