Stariharm
Stariharm's Achievements
  1. Will do.
  2. I'm only selling it to put the money into my other truck plus hospital bills from a new baby are starting to roll in. I love the truck and it's a blast to drive just not practical to have two trucks
  3. Ive seen a few when i first looked into making a 4 door but they just cut a cherokee right fon the middle of the rear door filled in the seem and somehow got a piece of glass in the half window
  4. The pics of the build looked really clean. The guy had hundreds of them than he let me go though. The only part that is "bad" is where he had to "ad" door to fill in where the fender would be on a Cherokee which he just cut that out of the Comanche doors and that lower part of the door on the cab part is Comanche as well. But where the shaping issues cam in was that the Comanche is actually a tad wider than the Cherokee. I do see where you are coming from though doc in the sense of what other corners were cut but as far as I can tell that's the only real flaw which is an easy fix. I even had it "flexed out" today and went all around it where the two came together to see if I could spot any cracks or twisting and it all looked good. So are you planning on building one doc or what build are you talking about?
  5. Its cherokee up to about 2-2 1/2 inches back from the back door. Then its comanche grafted on from there back. He said he shortened the bed up 12 inches because he didnt like how long it was. The frame is sleeved with 1/4 inch plate steel where the graft was. Not to happy with the rear doors either doc but they don't leak and just need to be shaped better which won't take much. I was mainly looking at the fact that the hard part was already done and now its more or less just a few cosmetic things to smooth out. It tracks straight as arrow and cruises at 75 very comfortably which is also a plus in my book.
  6. Perf ct. I'll have to give it a try. Thanks
  7. Pure but there is nothing on the mobile either just type and post.
  8. Doc I just emailed three pics of it to you if you wouldn't mind helping me out
  9. Nothing there either. I'm using an iPad if that helps
  10. I don't have an image button. All I have is a text box and a bottom that says post
  11. Did those work
  12. Empty Post
  13. Empty Post
  14. Empty Post
  15. Longview wa. I would up getting it. The guy had pics of it from when he built it 6 years ago with time stamps ha. How do I post pics?
