wooster_comanche87
Everything posted by wooster_comanche87
  1. But the trip was cut short due to a pesky stick deciding it liked my side wall more that the bush And got the tire fixed and met up with a fellow Manche owner
  2. And decided to name her SKRAPy Took her out to the desert to play a bit
  3. Rather than buy to grear carrier for the 4.10 I found a Dana 35 re geared at 4.88 Out with the old in with the new
  4. took 3 attempts at this hill to get up but she finally made it
  5. took her out to the desert to play around a little for being 2wd and 3.08 gears she did really good
  6. A pic from the school parking lot i had to get this one because she looks good
  7. got some decent 33s with the stock Xj wheels
  8. got the inside cleaner out and decent with some seat covers and a center console out of an Xj
  9. learned to drive the standard and built a custom gear sifter out of some spider gears laying around
  10. worked at a friends house and he gave me a Dana 30 high pinion with 3.55 gears and he gave me a set of 4.10for the rear to replace the 3.08 that are in it
  11. Well I was thinking when I put the I6 out of a Cherokee I'll just out a section of carpet and some headliner to
  12. When I first got the Jeep I pulled out everything carpet headliner anything that was bad and trashed it I was looking for an alternative to carpet
  13. Well it was the fact I wasn't looking hard enough found the power wire
  14. The problem in having is that the factory harnesses don't have any juice in them and can't find out why
  15. On the radio harness I'm using a volt meter and am not reading any juice in the wires any idea whys that I've tried tracking the wire and can't find were it goes should I just run new wires?
  16. No itl be insulted because of the heat I'm in Texas so yea the heat is an issue when I convert it to 4x4 with a inline 6 I'm using a Cherokee of the same year so I'll just cut some carpet out of that and throw it in my Comanche
  17. Like when I cut out that panel I welded a new plate in that spot
  18. then today i started on making my doors removable was a pain getting the star heads off the door
  19. bucket seats are in new shifter knob is in
  20. the same day i brought her home ripped out the seats giving the bracket to another Comanche owner for his bucket seats carpets gone head liner and visors
  21. the first day i brought her home
  22. this is what the interior look like the first day...it had to come out
