190ematt
Everything posted by 190ematt
  1. thanks, i did back when i started the account, but i sold it, it was an 84 with amg spoilers and it was a 5 speed but it had the 8 valve 2.3 not the great 16 valve but it was still a very fun car and noone knew it was an 84
  2. and the cat wasnt clogget, the tps was fried. it had 5volts goin to it and no power to the reference wire to the pcm so i replaced the tps and it feels great. now i just need to replace my cardboard tb gasket and put another valve cover gasket as it seems i may have overtightened it and it pushed out the gasket so it starts smokin under the hood at idle
  3. i just replace my tps and map sensor air line and an egr air line and it runs like new. i hooked it up to a solus pro scanner and ssaw no signal from tps, and i checked the conection and the tps was getting 5 volts but no power to the reference wire that goes to pcm. the reason i know mine was bad was the fuel line at the the tb directly above it had been leaking onto it. btw i need to fix that to but otherwise it runs great.
  4. all is well now, i solved the problem. really i should have done it to begin with but it was those 2 air lines i broke 1 was the map sensor line and the other was egr to tb. i rellaced those and started it up and it ran great, then i took it on a test drive and it rode great then started back firing and bogging then it came through itt, i put fresh gas in , figured thatd be it since it had been sitting for 3 months. did that and it feels like the cat is clogged. and it makes sense. i need to get the right relay for the fuel pump and get a new cat put on and the truck will be like new again i hope. but i idles very smothly and drives very smooth even though it accelerates so slow.
  5. well its puffing what looks like black smoke. i work in a shop so i opend the bay door. but befor i replaed the motor i had an egr prob but it was mor of an eraticly loping idle. and i broke 2 evap hoses in the process of the swap. 1 went to the tb and the other 1 went to the tb boot . they are hard plastic lines so they break easy I'm wondering if this could cause this, I'm going to the dealership tommorow to try and get those two lines. so tomorow il replace those lines.
  6. i have the same exact prob with the comanche i just put a motor in, in that vid u posted mine runs exactly the same. when i plugged in the o2 from the new old motor wich i didnt install til recently it cleared up for bout 5 seconds, I'm thinking bout getin a new 02 tommorow. th reason i just pluggeg in an 02 is cause somone who helped me align the driverside engine mount he broke the o2 with a prybar. so i just got around to swappin the o2s. when i swapped motors i used the intake and exhaust from my orig motor due to evap routing and conections, ive also replaced the coolant temp sens. but a badly gapped spark plug played a big role in it alond with cylin 1&3 ign wires being crossed . but after all that it still runs like your vid,
  7. okay update: i swapped the fuel pump relay with the one next to it and it fired right up, but the motor has a constant miss, feels like its outa time and the dizzy bolt was loose. i think someone pulled out the dizzy and put it back in wrong or somethin. i am getting frustrated with this comanche. is there a technique to re-align a dizzy , i am an advancing oil changer and some of this stuff is getting outa my reach. when it first started up it ran horrible it had a crossed wire and a plug with carbon in the gap. so i fixed that, ran better, then i replaced the coolant temp sens. and o2 sens, and it ran like normal for a quick 2-5 second than back to normal.
  8. could the the tps have any cause in this
  9. i recently put a motor out of am 86 into my 87 cause the motor went due to unkown reason. i swpapped off of my old motor including valve cover, intake and the exhaust manifold. today i finshed hooking everything up , i made sure i connected all my grounds, all conections except for two small air hoses that broke 1 to tb and other to tb boot. before i swapped the motor the truck ran. well i tried startin and it would just crank and crank and crank but no start. i put an injector pulse light on the single injector in the tb and it didnt light. so i poured a little gas down the tb and it fire right up. the cps wasnt damaged durin the proces to my knowledge but someone that was helping had a prybar in that area and broke my 02 sensor so he may have hit it but he didnt tell me. and does the cps eveng give power to the injector. and i disconected both fuel lines at tb 1 at a time and no fuel came out of either when i tried priming. any suggestions.
