Hey all,
I am a brand new user to this site and i have had my comanche for about 6 months.
It is a 89 Sportruck 2.5 2wd w/ ax4 4speed. I did a engine swap and the new (to me) motor won't run right. We have all the vacuum lines hooked up correctly to the throttle body, map sensor, and everywhere else they go. I thought the issue was in the timing, but this motor does the strangest thing i have ever seen. We hooked a timing gun to it and it stays at 10 deg before or after tdc (i can't remember the spec but i think it is right) no matter where the distributor is. This absoultely boggled me because it has points and a rotor. How can the spark be whenever when the rotor has to be near the points? It has no power and from what i know about engines, it sounds like the timing is off. It will run and drive, but it has no power and will occasionally fire out the top of the throttle body.
The motor didnt come with a throttle body, distributor, or cps. From what i understand from this site and others, this motor uses the renix ignition control system. The motor that was in it (which i don't think was original bacause it had XJ on the intake manifold) had the renix system as well so the cps that was on my bellhousing would be renix and my flywheel flexplate has the big notches in it which is also indicative of the renix system.
All i did to the motor is re seal all the gaskets. The only critical parts i removed were the pushrods, valves (hand grinded), and the rocker arms. Everything was labeled and put back exactly as it came out. I didnt touch the crank, cam, or pistons because that is beyond my expertise.
I am at the end of my knowledge with this so any help would be much appreciated.
