Hey guys, I have a 2.5l tbi 5 speed Comanche that is misfiring and running lean. The components I have already replaced, include, map sensor, plugs, wires, distributor cap, and rotor. I have tried two different ignition coils. I have checked the voltage differential in the tps sensor and it is within range, I tested the ohm differential across the Mass Air Temp sensor and it was 1000ohms which from what i have read is spec. Yet when i pull the plugs they are dry and nasty which leads me to believe that is running lean. I'm at a loss as to where to go from here, any help would be much appreciated.
