xjzjwjmj09
Everything posted by xjzjwjmj09
  1. I removed mine in about 20-30 mins removed the rubber gasket and took some speaker wire i had laying around stripped of the rubber coating on the wire then worked it in a corner. Then slid one end of the cable into the cab then worked my way around the window.
  2. sorry 87 long bed 4.0, removing the bed due to heavy rust damage. Might go flat bed route or replace/repair skins. Plastic shield, tank was leaking gas right at the fuel pump assembly, and the filler neck. I drained the tank and cleared the fuel rail. Just don't want to see it go up in flames.
  3. Hey guys new here and need a little help. Trying to drop the gas tank but I can't remove the sheild or strap bolts. I have hit them with pb blaster for 2 days and still no luck. I am a little reluctant to cut anything being that close to the tank. suggestions anyone?
