so the underside has the usual rust spots, mainly suspension but the driverside floorboard has holes. nothing I can't fix, especially with a little lift kit, and ill clean things up as I am doing it. It needs small things, like the plastic piece on the pillar by the door. the tailgate support, one side is perfect, other side looks like it went a few rounds with Mr. Tyson. and the paint job is $#!&, it was redone last year and it looks good from 200ft away. I think if I get the bed line-x ill look into doing something on the body, maybe the roller stuff. tires are dry-rotted, so a lift a tires would be necessity. the seat is ripped and the headliner is $#!&, but besides that it looks to be just a good little honest truck. I think ill try to talk the guy down to about 1,000, if that. I would feel comfortable, after fixing all the little things and lifting it, being in the truck around 3,000. but then, if i go with a 3 in lift and 31s, how bad do you guys think ill need to regear? would it be doable, or could/should i lift it and put stock size tires on it? anyone do this?
