xjman4
Everything posted by xjman4
  1. cool, thanks guys :D
  2. wow you guys ROCK!!!!! thanks so much for the much needed lesson :D
  3. but having the jeep in four wheel drive the entire time will ruin the tcase when i drive on dry pavement won't it? also will i be able to have four low?
  4. thats exactly what i want to do!!! I heard there was a kit to do it with that gives the needed seals and block off plate.
  5. thank you so much!!! you guys here at the Comanche club are always so helpful :D
  6. i have a 1987 Comanche and the 4WD doesn't work. i have it up on jack stands and the front drive shaft spins but the front tires don't. any ideas?
  7. haha my blinkers stopped working too :D
  8. no Reno Nevada
  9. how should i flat tow a mj with manual tranny and four wheel drive?
  10. ok so i just bought a 1986 jeep Comanche but the seller says it needs a new throttle body to run. it will run if you pout gas in the engine but not if you try to start it without pouring gas in. also will a I4 with a stick pull my 1,000 pound trailer up steep grades? any help would be great. :D
