I am in the process of rebuilding my comanche, I got it for free and it hasn't moved or ran for about 3 years, I got it all running and have driven it quite a lot offroad, I just recently changed the oil/filter, spark plugs, most of the fluids other than coolant, I have also put in new sunpro gauges. I did all this in one day and the next time I took it out it seemed like it was overheating. The only gauge I don't have hooked up and working properly is a temperature gauge so I'm not sure if this is even the case yet. But it starts up and runs fine for about 20 minutes then it will bog down whenever I give it gas, I can sit there and let it idle all day and it idles perfect, just everytime I give it gas is when it will start to act up. If I let it sit for 10-15 minutes and try it again it will do it all over again (run perfect for about 20 minutes then act up). I figured it was overheating because when I had it shut off for a little while it ran fine again. So I took it back home, drained all the coolant and put new coolant in, took it out the next day and this still didn't fix the problem. After talking with a couple people they told me to check all the electrical connections and one thing I did notice was when I put the oil pressure gauge in I took out the oil temp warning light sending unit to take the place of the oil pressure fitting, would this have anything to do with it overheating, I have not done anything different to the truck other then the things listed above so I'm not sure why it started doing this all of a sudden
