jason
Everything posted by jason
  1. Yea i gonna try and do all one last time from right rear to the front
  2. Kool. Havent never herd of them but will definatley check in on them
  3. Yea eagle thanks for your input. Guess i gonna start checkin in on one. Figured id try the cheapest first.
  4. Nothin. Put a new front end under it with a locker. And now no brakes unless u pump them up about 10 times then u loose them again
  5. Welp another bottle of brake fluid down and still no brakes. Started with passenger side and worked it over. All kinds of fluid comn out but still no brakes. Gettin quite agravated. Put diffrrent calipers on that can off another front end just like it and done the same thing. Still no brakes.
  6. K i try it in the mornin and see what happens. Start from furthest away first aint it. Thank you. Let you no what happens tomorrow.
  7. Yes. I had to go check but yea there on top.
  8. 1986 4x4 companche. Changed both calipers on front and tjen bled them. Still no brakes unless u pump them up about 10 times. Then lose them again. Trying to gravity bleed them now but only one side will gravity bleed. Any help will be greatly appreciated. Thanks
  9. K thanks for the comments. Will definatley b checkn it out. As soon as the weather gets above the single didgets a little. Thanks for the help.
  10. I got a 1986 comanche 2.8. Stock. 5 speed. Runs great. Goes into 2wd and 4 wheel low fine but when it goes into 4 wd hi its like its still in neutral. Any sugestions. Like linkage or somethin internal.
