polarbear
polarbear's Achievements
  1. Could you send me a link to the procedure? Icant seem to find it anywhere.
  2. I did bench bleed the master, and did a complete bleed at all wheel points (started furthest from master and working towards it). And I didn't do anything to the proportioning valve, not really sure what to do with it. I can say that the front brakes are what feels to be failing to brake the truck with the first pump (leading to the second pump and the front brakes then working)
  3. Alright, so i have a 1988 mj, 4 cyl ax4 2wd, recently i was driving and went to hit the brakes and the pedal went to the floor with very little resistance, after one pump they began to bring me to a stop. I have replaced the calipers, rear wheel cylinders, brake booster and master cylinder, and i still have the issue... any suggestions??
