ninjaturtleMJ
ninjaturtleMJ's Achievements
  1. Will do thank you very much!
  2. Have not gotten to draining trans yet but have checked and topped it off, but I have drained and changed transfer case, have topped off my front diff (need to drain and change it before winter hits), have had to swap my rearend (broke the carrier in the old one in half) but new one has been drained and changed. All in all I love my MJ!
  3. Thanks Pete and cruiser I have put it in 4h several times today doing the same way cruiser described and it has worked every time
  4. well its raining here in MO and I'm off work because of it.....so I'm going to go do a little wheeling ;)
  5. Ah ok well I will try that out today...thanks :)
  6. I have a 86 not sure of what t case (someone said probably 207) but I can go from 2wd to 4lo and back to 2 wheel no problem but it won't engage 4hi....it just acts like its in neutral. I have found tho if I let it roll backwards and throw it in 4hi while rolling it will engage (but it won't work if I put it in reverse to get it rolling backwards only if I let it roll by itself off a hill) any ideas as to why it is doing this? maybe just time for a different one?
