Thank you for all of the responses. I will try and answer all the questions asked. It only makes the noise when driving vehicle in 1,2,3rd and reverse.. The clutch does not feel right, not much clutch there. The clutch disengages and engages close to the floor. I have to hold the pedal close to the floor to shift now, I didnt have to do that before. The fluid was changed and there was metal in it. When the throw out bearing, clutch etc was change it did run better for a day but the clutch felt bad, after that it started making the metal on metal noise again. I just tried the transmission with the transfer in neutral and no noise. When the transmission is in nuetral you can hear noises and when the clutch is pushed in it stops. I'm lost on what to do. If I take it in to a shop it will cost me hundreds, if I let a backyard mechanic do it most likely it will not be right. What to do?
Thanks Again for all of the replys, I will let everyone know what the problem was. Any info or suggestions will be appreciated.
Thanks
Rich
