merikgvr4
Everything posted by merikgvr4
  1. Temp goes to normal range. One fo the first things we did was replace thermostat. Will check on the vacuum hoses. Thanks
  2. ordered cts from autozone. is it hard to replace? tight space? Thanks Spokewith my broHigh CO and HC. Any other things to check for what causes this? Thanks. Erick
  3. We go to the same smog guy so he pre runs the car for us. I'll double check with my bro if the HC is also high. Thanks for the replies.
  4. coolant temp sensor. Sorry
  5. My brothers Manche failed smog, high CO. Previous owner seemed to have replaced cat con. We bought ebay injectors and also replaced 02 sensor. Still high CO. Will replacing the CTS help? If so, any pointers on how to replace the part? TIA for any help.
  6. Is Autozone the same as Advance?
  7. Hi rich, we cleaned up the socket and bulb. Still no worky. Will look at a replacement socket when i hit the yards.
  8. Thanks everyone for the warm welcome. We worked on her some more today. Replaced thermostat and now get proper temps. Also replaced cap and rotor, had a crack and my bro told me she runs beautifully now. I asked him if he notices the wobble around 55 and he said he didn't notice, will still do the check on the front suspension when we work on her again. I problem he wants fixed is the front left signal doesn't work, everything else works. Is this a common problem with the Comanche?
  9. My bro is a fireman and his commander gave him an 88 Comanche. Body is straight and we are loving it. Bought some mesh wheels from CL and looking good as well. here are some pics. She cleaned up real nice. She has a few problems though. First idle is not steady, will try cleaning up the ISC and TB. Where can we source new vacuum lines? Water temp is low, probably 2nd white line at the most, will replace thermostat tomorrow. Fixed most of the light problems with the fuse box. Will check tom if clutch master is leaking. Some of the contacts in the fusebox is not tight anymore. Will look into replacing with a better one from the yards. When we drove home, front steering made a wobble around 55 but goes away around 60 mph. What is the likely culprit? That is it for now, will update tomorrow when we work on her again.
