kutter79
kutter79's Achievements
  1. so i found out that my rear brake line is rusted through and starting to leak right under the cab. I hate to have to make my own. does anyone know where or who still sells them? tried a couple local auto part stores say they don't. thanks for the help.
  2. here is pics of mine, so anyone can see if that bottom spring is factory or not. not sure how much lift the shackles are either. I'm wanting toget rid of those too. don't know how to load pics yet. here is link.
  3. that is about what i am lookin for. thanks
  4. i just plan on runnin the stock leaves in back. another reason i was gonna remove the flat leaf was for a little more flex. so did you just reuse your factory u bolt plate/shock mount? how much lift are your shocks for? thanks for the pics.
  5. what size tires are you running? do you have a side pic? thanks
  6. so I'm thinkin of doin a soa on my MJ i got about a month ago. it has a 2" now. gonna put 3" coils with the pucks in front, and rubi LCA. want a better ride so was gonna do a spring over and remove the flat overload leaf. so I'm wondering if I'm gonna need a 1" shackle with the soa or just find a stock set to put on to match the front. thanks for the help.
