Hi Eveyone,
I have started the process of replacing a worn out slave cylinder. It's an internal cylinder on an AX15, and its going well so far: the transmission is dropped, the old cylinder is off, I have a new retainer nut to put the new one on. I am running into an issue with the quick connect fitting that is on the new cylinder. My first thought was to remove the quick connect piece, and to connect it the way the old one came off. I can't for the life of me seem to get it off. After stripping the nut some I used a vice and it still wouldn't budge. I figured it might be easier to find a fitting that I can attach to the old clutch line, but I can't seem to figure out which of those i'll need either. Does anyone have any guidance?
Nathan
