madmanche
Everything posted by madmanche
  1. As you can see here. The slider is close to the door and close the truck.
  2. This is how i do my door rocker's I use 2x3 tubing end the weld quarter inch flat bar Under it. The flat bar is to fix the rock sliders
  3. This is the Inside of my custon bed The close front part holds the gas tank and 2 optima battery I also run with 2 power tank, 1 35'' spare and a Warn 8000 pound winch
  4. Full 97 interior with cage
  5. There was only 2 steps on my truck that were not done by me. Full sand-blast of the frame and cab + black primer And the mecanical swap that was done by part vendor.
  6. This picture show's u the 2 truck being mix. You can also see the drive way were almos all the work was done
  7. This picture is shows it's of road mode :) Bed side's and door's off
  8. And now after 2 year of drive way built This is my Comanche. And yes i know that it look's like the Zone off road truck...
  9. This is what i was running back then, 1997 xj, 6'' Rubicon express lift, 35'' tires, dana 44 from a 2005 Rubicon TJ and 4:1 terra low.
  10. So here i go. Been working on my projet for 2 years now. Now that it's done i can share with u what i have been working on. My truck started as a 1989 short bed.
  11. Then welded a tube all around. All this because of rust
  12. First thing i did was to weld a flat bar
  13. Yes, took parts from it for my Comanche ;)
