Dmac0312
Everything posted by Dmac0312
  1. Replaced my worn out serpintine belt with a new one, the new one has been squeaking like crazy even though i sprayed it down with belt dressing, ive tried about everything and I'm starting to think it may be a problem with one of my pulleys, where should i begin my diagnosis?
  2. When you say 10-1.50 do you mean 10x1.5x30mm?
  3. Hey guys I misplace all the bolts to bolt my bed onto the frame :doh: I was wondering if someone can tell me the correct size of each bolt so I can go to the hardware store and pick up new one, I know there are six of them and if i recall 2 are nuts and 4 are bolts, any help would be appreciated
  4. yes it is the same sending unit that i took out, i will switch the wires and see what happens, hopefully thats the easy fix :banana:
  5. Hey guys I'm having some trouble with my fuel system, i took out the sending unit in order to restore my tank a bit and i re installed it twice and my gas gauge is still reading low when i have plenty of gas in the tank, i took it out a second time to see if the float was stuck but I'm not quite sure if it was or not, how can i tell if the float is stuck and is there a certain way to put the sending unit back in the tank to assure the float won't be stuck?
  6. Is this lock plate removal tool a common tool that i can pick up at an auto parts store? doesnt sound it :???: also has anyone else done this without the tool if so how difficult was it?
  7. Hey all new to the forum here and currently have a small project ongoing with my 87' MJ, my turn signal arm isnt quite working properly and doesnt feel snug I'm thinking something is jammed up internally or broken and am trying to access it but am having trouble, i have taken the steering wheel off but can't seem to get past the steering wheel lock, any adivce will help
