Buck
Buck's Achievements
  1. I would tend to agree it is an underrated rear end. I would just wonder why on an MJ with such a beautiful suspension and such a great powerplant, they would stuff a 20 back there. There are so many better choices that would be a better match to the suspension, HP combo that beast is going to have. I would at least truss it, the weakness is in the flexibility of the housing. Trussed, it may likely last forever. Good luck anyhow on a sweet looking rig!
  2. I have never heard the AMC 20 referred to as a great tough axle. :huh???: A 78/79 Ford hp60, a Gm corporate ff 14 bolt, are "great, tough axles." The 20 has a notoriously weak and flexible housing. But to each their own, I'm sure the 20 is sufficient if you run a small enough tire. In my 20 years of offroading, i've never once heard of the 20 as a great, tough axle. I know the ring and pinion are beefy, I also know the cj units with the 2 piece shafts are less desirable and more weak than the waggy units. Hell, I had a amc 20 under a cj-7, it held up just find with the 4 cylinder... :D But that sure as hell wouldnt be my axle of choice behind an LT1. :hmm: Some more amc 20 info, http://www.jpmagazine.com/techarticles/ ... ndex1.html , my favorite line in that one, "the amc 20 is marginal in a stock application. And some amc 20 tech, also describing its tendency to flex, http://www.jpmagazine.com/techarticles/ ... index.html . Great and tough, i don't think so. Adequate for a smallish tire, semi trailed rig, absolutely. Seems you are mis-informed. The AMC20 axles are great, tough axles. The CJ versions were weak until the one piece conversion was done, but then they can easily handle the power of a big V-8. The Waggy 20 is definitley the best of them with the strongest housing and one piece stock.
  3. I didnt even know AMC 20's were offered in the mj. Learn something new everyday. As far as I know, though, all AMC 20's, while having quite beefy ring and pinions, have very flexible housings. So is this the same 20 that was offered in the Waggy?
  4. Is that an AMC20 rearend? And if so, why?
