Howdy all. I'm a noob here from Lyman, SC. I just bought a 88 4.0, Pukego BA10 tranny, 2 wd. I'm not new to jeeps as I also have a 88 YJ, 89, XJ, and 95 ZJ. The MJ runs great but above maybe 60 MPH when you let off the gas and cruise it seems to miss. Touch the gas the tiniest bit and it smooths right out. I have some RENIX experience from my XJ so I have a few sensors, etc laying around. I think maybe starting by cleaning the throttle body and IAC, replace the TPS with a known good one. All vacuum lines look to be in place but I'm going to go a little more in depth with them. It feels like a lean condition but I know that can be misleading. I'm fairly sure it's not electrical because if you hit the gas it smooths completely out until you back off again. Another thing I noticed a few hours ago was that my idiot lights had gone out. I whacked the fuse box and the blinked back on. After further checking I found the dreaded clutch master cylinder leak. What is the best way to clean this up? Carb cleaner and compressed air and check all connections? Thanks.
