stern82
Everything posted by stern82
  1. They just might be, I think they are different thickness if memory serves from when i installed. Either way it is work a shot. Thanks again for the help!
  2. I have a 2002 Jeep Grand Cherokee Overland with a Teraflex budget boost on it. I am taking this lift off and was wondering if anyone know if either set (front or rear spacers from the WJ) would fit on the front of my MJ. My MJ is a 1989 2wd with the non HO 4.0 long bed with an auto tranny. The front of my MJ could use a little bit of a lift as it is sagging just a bit. Thank you in advance!
  3. BLHTAZ thanks for the response and I will try that when I can get her into the shop because it is about 15 degrees outside around here right now!
  4. I have a 1989 Comanche that has about 155,000 miles on the 4.0 non ho motor. I had some eratic idle issue this past summer and just cleaned the throttle body really well. This morning when I got to work and put her in park she cut off on me. I started it back up and she idled really high then shut off again. Any thoughts? Could it be the the TPS needing to be cleaned again or possibly something more. It is Renix by the way. Thank you for any help!
